Hooking up 2 motors
PA
Two brushed motors can use a single ESC. Two brushless motors require two ESCs. If they have built in BECs, you may have to disconnect one of the BECs from the receiver. Castle Creations has some good guidelines for putting together multi-motor brushless power systems, check out page two of the newsletter below:
[link=http://www.castlecreations.com/media/castle_scribe_archives/Castle%20Scribe%20CE-03-Mar2006.pdf]Castle Scribe March 2006[/link]
The jpg graphic below summarizes their suggestions:
If using brushed motors, use a single esc wired with motors in paralell. Good example is a multiplex twin jet of mine. Using one esc, the motor leads are split off to each motor, the + lead splits into two leads going to each motor's + tab, the - lead splits into two - leads going to each motor's - tab. If brushless, go with above from castle creations
. If you series wire the 2 brushed motors, you cut the voltage to each motor in 1/2, if paralell they get the full voltage from the battery. Just remember that you will also double the amp draw that way so you need a controller with double the capacity of a single motor setup. Hope it helps some [sm=bananahead.gif]
Hey CBM...
If you were to use 4 motors for that same scenario and wire them in series, would the voltage be cut to 1/4??? I have 4 little 3v motors that I need to wire up. The motors are brushed....
Z
Z
PA
ORIGINAL: Zim-uh-tosa
Hey CBM...
If you were to use 4 motors for that same scenario and wire them in series, would the voltage be cut to 1/4??? I have 4 little 3v motors that I need to wire up. The motors are brushed....Here is the link to my original posting for more information. [link=http://www.rcuniverse.com/forum/m_8568907/tm.htm]Motor wiring problem[/link]
Note: I am aware that this may be viewed as a double post, but I really need some help before I blow something up...My apologies in advance.
Z
Hey CBM...
Z
PKH..
Thanks for the great info so far....The motors are indeed all the same and run 2.4-3.0 Volts. I do know that these motors have been run successfully in series from a 7.2 volt battery (3.6 volts per motor) without issue. The scenario for where I got this idea was 4 motors on a 7.2 battery but wired so that 2 motors in front are splitting voltage and 2 motors in the rear share the voltage in series as well!! So...As long as it is possible to wire the same four motors to share the entire voltage of my battery and in series, I am golden on my wiring project. Even if my batteries run a bit high on volts I will not worry for now...
In my linked question, I stated that I am not running these motors in a plane. I just wanted to clarify that again. Here is a link to the motors I am using x4...[link=http://www.hobbylinc.com/htm/tam/tam15317.htm]Tamiya Power Dash[/link]. I wish these motors had an amp rating so I knew how big an ESC to go with???
I really appreciate your help. If you or anyone knows of a way now that I can utilize my DX6i to turn 2 of the motors off if I wish, that would be a nice added feature.
Thanks so much!!
Z
Thanks so much!!
Z
