Slow stick bent prop shaft?
GA
Hey everyone I need some advice. I bent the prop shaft on my slow stick motor. I bent it back to somewhat normal and put on a new prop, but it flutters out of balance too much. The motor is still good. It is a 370sd mo.4 66t gear on it. Can I just get e replacement prop shaft somewhere? I don't think a new motor will help because it will probally just be the motor without the prop shaft. I am thinking of just buying another slow stick kit for parts. Would that make the most sense? Thanks Jag.
TN
