What is the problem here!!
Hi everyone
I bought recently a brushless setup for a profile 3d plane to practice some 3d,
now I have a problem with my setup
-Rimfire out runner (28-26-1300kv) Max. constant current 15A - Max Surge current 19A Max. constant Watts 165W - input voltage 7.4 or 11.1 sugested prop with 2s bat. 10X3.8
-Robbe ROXXY brushless ESC 900 serie : Load Current 18A Peak Load 22A
-Proppler 10X3.8
-Battry Lipo 7.4 (700MA) 10c
-2 deferent radio and receivers (the same result)
The problem is when I go full throttle gradually and smoothly (like in one second) I have no problems building-up the full speed of the propeller BUT when i go down to about half throttle and then go full throttle again very fast (jumping the stick)
the motor delay about second or so until catching the full speed again!! and while that happening the little led on the ESC show little red peak??
with my setup as described above I don't know is it the ESC not enough for the motor or the Battery not right? do I need 3s 11.1 with higher (C) number battery or higher ESC amp ??
also I Notes that the delay time change from prop. to another for example the 9X7.5 had more delay than 10X3.8 and without prop. almost there was no that delay!
Thank you in advance I really appreciate your Help
Mo.
-Proppler 10X3.8
Mo.
Thank you for replying,
It's programed for airplane , air break off and lipo battery,
I did program it using the throttle stick as user manual said, but there is some other options you can only have it with commander attached to the ESC like soft cut or so ..
But what do you think this ESC as describe above (18A) is weak for this motor (15A) or it could be more for the battery ?
Mo
Mo
My thoughts are that it is a programming option. The slow ramp up of the throttle leads me to believe that would be the helicopter setting. However, I also believe the led coming on is an indication of maximum output from the ESC. Does the led light as soon as you quickly increase the throttle of is there a delay there? or does the led not light until the motor reach full speed? Wish I knew something else to try, short of changing the battery to a 3S.
ORIGINAL: LSF2298
sorry I am new and this is my first brushless setup
mo
A 10C battery rated at 700 mahr. IS DEFINATELY going to collapse when you go to maximum power.
That is what is causing the delays to full throttle.
ORIGINAL: cyclops2
what do you think how many C would be enough for 15A motor with 600-800mA 11.1 v ?
Thanks cyclops2, I completely overlooked the 10C battery. The new battery, and I defer to you for a recommendation, should resolve the problem.
TN
ORIGINAL: PcMac
Thank you for replaying
ORIGINAL: cyclops2
To all people with ANY TYPE OF A POWER PROBLEM.
Get a DIRECT answer from Dr Kiwi. He IS the power master.
I just generalize, until he hopefully appears.
Thanks again, Phil. It is very satisfying to see a smiling face on another customer.
Rich
I bought today 950mA 11.1v 25C battery, wow everything went perfectly, Thank you so much guys I really appreciate your help.
Mo
Mo
