robbe ro power Lipo batteries !!
Hey guys did anybody try this Batteries???
it's written about it the fallowing:
Extra safety:
Specially treated Lithium material: batteries do not burn and do not explode, even if mishandled in any of the following ways:
Drilling a 5 mm Ø hole through the pack
Bending the pack along its length with a force of 13 kN
Slitting the centre of the cell, approx. 15 mm
Heating to 150°C for ten minutes
Overcharging at 5 Volts and 0.4 C for about 2.5 hours
Reversed-polarity charging at 5 Volts and 0.4 C for about 2.5 hours
Short-circuiting with 100 mOhm for 2.5 hours
All Ro-Power LiPo batteries are fitted with a voltage sensor lead for connection to robbe Equalizers und Lipomat chargers.
[link=http://at.robbe-online.net/rims_at.storefront/49c37865004d3bf8271c3e0dc146067e/Product/View/1&2D4825]The link to their website[/link]
if any body try them please give us a clue
Mo
Extra safety:
Mo
Agreed.
DOT testing similar to a LIFEPO4. Only cells I now use or even have on my property.
And a FMA Cell Pro 4 charger.............What worries.
Life is good.
Well I bought my self one of this, 3S 950mA 25C, looks sold, a bit heavy 95gm,
but I don't have enough bal** yet to try to drill it and see it will burn or not
Never beat a new dog.
What is the cell voltage when charged up ?
3.5 to 3.1 volts SHOULD be LIFEPO4 The safe type.
4.0 volts & higher is the vicious bitting dog LIPO is his name.[:@]
Warning!!!!!!
You are asking for some VERY nasty flash & heat if you punch holes in a LIPO delibertly!!!
The heat approaches that of a road FLARE. Severe hand & face burns are a real possibility.!!!!
Do NOT do this dangerous test, it is not needed.
Rich
ORIGINAL: cyclops2
and it was written in the user guide that the lithium base material of it has been modified using a special process with the result that they do not burn and will not explode. hopefully,,,,
ORIGINAL: cyclops2
Warning!!!!!!
Rich
Warning!!!!!!
Rich
Thank you for not risking injury.
I am GUESSING you have LIFEPO4 due to the 4 volt cut off range. Contact the company to be VERY SURE.
Enjoy
I WENT TODAY (25-03-09) TO THIS COMPANY WEBSITE TO THE LIPOS PAGE AND I FOUND THAT THEY REMOVE THIS EXTRA SAFTY FROM PAGES OF LIPOS ????
BUT I WAS BOUGHT ONE OF THEM ALREADY AND USER MANUAL HAVE THIS NOTES OF EXTRA SAFTY???
ANYWAYS ANYONE SHOULD NOT TRY TO DRILL IT OR DO WITH IT ANYTHING FROM WHAT IS WRITTEN ABOVE..
THANK YOU
MO
THANK YOU
MO
WA
The notes still exist on the Robbe website for these batteries here:
http://at.robbe-online.net/rims_at.s...1b3e0dc14605dc
Ro-Power : Specially treated Lithium material: batteries do not burn and do not explode, even if mishandled in any of the following ways:
# Drilling a 5 mm Ø hole through the pack
# Bending the pack along its length with a force of 13 kN
# Slitting the centre of the cell, approx. 15 mm
# Heating to 150°C for ten minutes
# Overcharging at 5 Volts and 0.4 C for about 2.5 hours
# Reversed-polarity charging at 5 Volts and 0.4 C for about 2.5 hours
# Short-circuiting with 100 mOhm for 2.5 hours
Amazing. I'd be interested to know what the difference is with these packs. It would appear they are higher voltage 4.20V (Li-Po?) packs with some of the advantages of A123s (safety).
- David
- David
ORIGINAL: write2dgray
- David
- David
I am happy for it because I am a bit crazy about lipo safety
