ESC Forward/Reverse
Hey All,
Any help with this would be awesome ... I'm not necessarily looking to fly 4-D but want to have thrust reverse for short landing and reverse on the ground for handling.
I'm using a MGM-Compro 2560 Z-Series ... which is a car/boat ESC and therefore has a reverse capability.
Is there a way to set up the radio so that a "Neutral" Throttle setting is the lowest point in one switch setting and once the switch is flipped, the reverse throttle curve is active?
Hopefully that makes sense. I basically don't want to try flying with the throttle in the neutral position ...
Brandon
Brandon
