testing the outputs to the motor
NJ
I have a 25amp esc from e-flite with a brushless 400. On the second fight of the day the motor smoke as soon as I plug the battery in. Throttle stick was low and everything looked normal. I know the motor is gone but what I would like to do is test the esc outputs to the motor without the possibility on cooking another motor. Can this be done with a DVM. If so what can I do.also the bec circuit is working i cann controll all flight surfaces
thanks
thanks
