Suggestions for a brushless motor
I want to buy a brushless motor for a sail plane weighing between 50 to 60 oz.
Please suggest a good motor/gearbox combination for operation with 7 cells.
Value for money is main consideration
Kinda rule of thumb is 50 watts per lb more is better inn the wind
Geared prefered for eff or outrunner. Get a trial copy of
www.motocala.com and do some trials C what you need. CU
The correct address for the free sample motor calculation program is - www.motocalc.com
My Feedback: (21)
Motocalc is all well and good, but it doesn't have a lot of the motors that are out on the market, AND if you don't know what the numbers mean, Motocalc data is almost completely useless.
Sarj,
The simplest, and one of the less expensive solutions is a Jeti brushless motor. Check out http://www.hobby-lobby.com for some ideas. Off the top of my head, I'm thinking perhaps a Jeti 15/4...
Sarj,
I have the MotoCalc program and find it quite good. It is true that it does not have data on all motors, batteries etc. But this program is regularly updated and the updates can be downloaded free of charge
