Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Prop size...
Old 07-03-2003, 12:24 AM
Default Prop size...
I have a T400 3:1BB gear box and a 400 motor...I am curious about what prop size I should use?? Right now I am using a 10x4.7 apc prop. Is there anything better?? Any recommendations? Thanks in advance...I would appreciate any input.
Old 07-05-2003, 04:52 PM
Get a trial copy of www.motocalc.com and try it maybe
even the different co of props. CU
Old 07-07-2003, 05:16 PM
My Feedback: (21)
Matt Kirsch's Avatar
The problem with "go get motocalc" is that most people don't understand the numbers that motocalc gives them. To use motocalc effectively, you need to know what you're doing. Otherwise, you're just stabbing in the dark, and more likely to come up with a bad setup than not.
A more helpful answer here is: Use a 9x6 or 10x6 propeller.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
