Adequate motor?
I'm building a BMJR Model Products model of the Timers Nightmare, a .020 size pylon wing OT FF, which I am converting to electric R/C. I'd say about 120 sq. in.
I also have a Scientech motor that is supposed to turn a Cox gray 4x2 prop @ 9000 rpm on 6v.
Should this motor work on this plane? Or should I find something else?
When not to go into Dodge. Keeping the weight down is the problen the Li-Poly's have helped a lot FMA has some very
lite high current types as many other people. Take a look a
a trial version of www.motocalc.com CU
