Transmitter Loss of Signal
I just installed a Turnigy Plush 30A ESC with a Turnigy 2200 Kv motor into an Easystar. I am sure I've missed something but if/when the Tx gets shut off (or in the case of a loss of signal) the motor goes to full throttle. Initially I had the throttle server reversed (new Futaba 7C Tx, I just had not bothered to reverse it yet) but that has been fixed and the problem persists. Does anyone have some suggestions as to what could be causing this to happen?
RE: Transmitter Loss of Signal
You need to relink the receiver with the throttle in the low position now that the throttle reversing has been set correctly, that will set the fail safe to closed throttle in the event of loss of signal
With a Futaba transmitter, you will want to set the throttle servo reversing to REV for any model that is E-powered. If all you fly is electric, it would be a good idea to go through all the model memories and set the throttle to REV for all the models, but always test a new setup to be sure. My personal method with new electrics setups is to link and test the model with out the prop, de-fang the beast
Pete
Pete
When you say "relink the receiver with the throttle in the low position" what do you mean?
I finally pulled out the manual for the Tx and set the throttle to REV for all models, so hopefully this doesn't happen again. I think I may have messed up the ESC programming so I went back through and reprogrammed it today but did not try a loss of signal. I'll have to do that tonight.
For Futaba radios when working with just about any ESC I've ever seen, the throttle channel needs to be set to REV
Make sure you set your fail safe to full low throttle. Hold the airplane and test it before you get chased across the pits by your own airplane, trust me thats embarassing.
