Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Nitroplanes Yak 54 .25 size motor suggestions
Old 03-23-2010, 07:46 PM
CastorTroy2150
My Feedback: (10)
Default Nitroplanes Yak 54 .25 size motor suggestions
Just ordered this plane..
http://www.nitroplanes.com/newyak543dfu.html
I am not new to flying or even Electric, however, I have yet to buy and piece together a power system for a electric plane. Most that I have bought are RTF or BNF, so the BAttery and ESC?Motor are included. Servos, and other electronics I should be good on, and I have plenty of building EXP. Any ideas on motors,ESC,Lipos would be awsome, maybe even some links! I looked at Hobby City as they come highly recommended with thier Turnigy motors. Thanks For the help!
Pete
Old 03-24-2010, 08:51 AM
jzrf6c
Default RE: Nitroplanes Yak 54 .25 size motor suggestions
It really depends on the type of flying you intend on doing. As a general rule, you'll need 100 watts per lb. You could get by with 75 watts for simple flying. But you'll need at least 125 watts per lb for aerobatic flying. I see the plan weight about 2.6 lbs so you'll need at least 260 watts.
Old 03-24-2010, 06:33 PM
Dr Kiwi
One reasonably useful rule of thumb for IC to electric is: watts = cubic inches x 2000.... thus a .25 equates with 500W... that's a goodly amount for a 2.6lb plane, but maybe worth pursuing.
Ah, I just found this... so a .21 is recommended so that is 420W:
Gas Engine Required: 2c 0.21 cu in
or...
Flying Electric Required:
Li - Poly :11.1V ; 2000-2200MAH ;
Propeller :9"x6" ; 10"x12"
Out runner Brushless Motor :450T Speed ;
Speed Controller : 40Amp.
I somehow doubt a 450T would cut it... but this might:
http://www.hobbyking.com/hobbycity/s..._1400Kv_/_550w
One of the HK reviews:
Very good engine, hard pull and smoth noice, efficiency near 80%
battery Zippy R 2000 3S lipo
APC E 11x5.5 40.9A 403W 9450rpm 74% 1742g (pull)
APC E 10x5 38A 375W 10680rpm 78% 1618g
Turnigy wood 10x4 37A 364W 10950rpm 1598g
Turnigy wood 11x4 41A 396W 9270rpm 1678g
Old 03-24-2010, 08:09 PM
CastorTroy2150
My Feedback: (10)
Ok, that is well within what I want ot spend, but I am looking for decent power, I would assume since that is over 100W more than the mentioned 420W...should have good success with that motor, right?
What about going with this motor/s instead?
http://www.hobbyking.com/hobbycity/s...0_750Kv_/_600W
http://www.hobbyking.com/hobbycity/s..._1100Kv_/_770W
You said the 550 might cut it what about the 600 or even the 770W, how big is to big lol, I will do some 3D, but I am not that advanced yet, basic hovers and knife edges etc....
Old 03-25-2010, 05:03 PM
CastorTroy2150
My Feedback: (10)
No responses I guess, sigh, What I would like to see is if this was your plane to fly aerobat/possible 3D what motor,battery, ESC, and the like you would use from HobbyKing or Hobby City. I would like to have links as well. DR Kiwi, I have read your posts and you seem to be very knowledgeable, so any input you give I would trust...thankS!
Here is what I am thinking of going with...
Motor-
http://www.hobbyking.com/hobbycity/s...dProduct=7708#
ESC-
http://www.hobbyking.com/hobbycity/s...idProduct=2166
Unsure of battery and whatnot, but any help would be great!
Old 03-25-2010, 08:28 PM
Dr Kiwi
That is a 150g motor... but it certainly should give you good power... if you can fit a big prop (13"+) on your aircraft.
It seems 600-800W on 4s is possible.
Old 03-25-2010, 11:14 PM
CastorTroy2150
My Feedback: (10)
DR. Kiwi, please, if you were to power this aircraft on the basis of what performance I am looking for, give me some info and links as to battery/ESC/Motor you would use....I really need some more specific guidence and I think you are a great source. I dont mean to sound helpless but I want to start out right...thanks! Price isnt that much of an issue, Im cheap but will pay for quality. this is a fun flier, and should be funded as such, I don not have to buy fomr Hobby City/King...
Old 04-04-2010, 11:45 AM
Coronado
Coronado's Avatar
