Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
E-Flite 60ESC pro 7 servos plus retracts ????
Old 03-27-2010, 05:46 PM
spool-it-up
My Feedback: (10)
Default E-Flite 60ESC pro 7 servos plus retracts ????
Putting together the E-Flite beachcraft Bonanza
total 7servos all analog plus the E-Flite electric retracts
the question is should i get a bec or run a seperate battery
for all the equipment. The motor will be the E-Flite 15
I am a rookie to electrics but not flying,
14years RC flying all glo and last 4 helis,
Just looking for the correct way to set thisup!!!!!
Johnny
Old 03-28-2010, 09:04 AM
Walt Thyng
My Feedback: (9)
Default RE: E-Flite 60ESC pro 7 servos plus retracts ????
Either way would work. Personally I use an Ultimate BEC from Kool Power for any a/c whose ESC can't handle the servo load. If you need weight to balance the bonanza, then go ahead and use a separate receiver battery.
FYI, since you are new to electrics, you must disconnect the red wire between the ESC and the RX in either case. Just use a pin to lift the locking tab on the plug, bend the red wire back and wrap it in electrical tape.
Another hint: all external BECs that I've seen tell you to ire the power lead into the esc battery leads. I make up an short adapter (as short as I can) to match the ESc and battery leads. The BEC is soldered into this adapter and can then be easily moved from one a/c to another. If you need a photo let me know and I'll get one.
You will eventually figure out that it is easier to standardize all you connectors regardless of what one they originally come with. I will not get into the fight over which one is better, just choose one that you like and go with it.
Hope all this helps,
Walt
Old 03-28-2010, 12:28 PM
Dr Kiwi
ORIGINAL: spool-it-up
Johnny
A Castle 10A UBEC should do it... here is a crude mock-up to show the connections
Old 03-28-2010, 05:05 PM
spool-it-up
My Feedback: (10)
Thanks guys i think the castle is the solution,
The only problem maybe someone can answer is
i have no open channels i am useing a Futaba7-C FAST2.4
and a 7channel reciever that every channel is taken up,
now where to connect the BEC
Johnny
Old 03-30-2010, 08:53 PM
Dr Kiwi
You must have a "battery" channel available?
Old 03-31-2010, 07:39 AM
Walt Thyng
My Feedback: (9)
usually you can use any channel with a "Y" harness. You don't say what brand of RX you are using, but many of them have a combined battery and last channel port.
WT
Old 03-31-2010, 04:21 PM
spool-it-up
My Feedback: (10)
Sorry about what reciever i am useing,
Futaba R617FS
Johnny
