Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Help: brushless motor speed control
Old 04-12-2010, 09:07 AM
pranav0091
Default Help: brushless motor speed control
Hi,
I'm working on a project involving brushless dc motor. However unlike in the case of RC airplanes, I do not have/need an RC Tx-Rx module.
My problem is that I don't know the waveform that the Rx module supplies to the BEC. I would like to make the motor run at a constant speed.
I understand that, in general, the signal will be time varying as one has to control the speed of the motor, but my question is-
Is the waveform a slowl time varying voltage, with the motor speed being proportional to the instantaneous voltage?
Is the signal a periodic wave, whose frequency/duty cycle controls the motor speed?
I'm stuck at this point in my design, and really don't want to buy a RC module just to check the waveforms.
Any help is appreciated.
Thanks.
Old 04-12-2010, 10:04 AM
whitecrest
whitecrest's Avatar
Default RE: Help: brushless motor speed control
Welcome to the forum!
I believe you are looking for a [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVK79&P=7]servo tester.[/link] The technical description at the bottom of the page should clarify the issue. You won't need a Tx or Rx to set your motor to a constant speed.
Good luck with your project!
Old 04-12-2010, 11:25 AM
pranav0091
Looks like it will serve my purpose.
Thanks a lot Tim. I really appreciate your help.
Old 04-12-2010, 11:37 AM
pranav0091
I had seen a post in this forum by a user who had an issue similar to mine. Here's some data I found on the net-
The signal to a servo motor is a pulse width modulated waveform, with a time period of about 20ms and an ON time varying from 1ms(off) to 2ms (on).
the signal amplitude can be anywhere between 3 to 6 V, though 4.7V is more commonly used.
Remember this is the signal to be fed directly to the servo motor.
This information has not been verified by me.
