Go Back  RCU Forums > Electric Aircraft Universe > Brushed/Brushless motors, speed controls, gear drives
Reload this Page >
Please help...servo action is cutting power to my motor!
Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Old 07-20-2003, 09:54 PM
quyetflyer
Default Please help...servo action is cutting power to my motor!
helo0...question for anyone who can help...I just built a new plane..and was testing the electronics and I knotced that when i activate the alerion servos to fast..the motor power dips down. Now, because the servos are running off the flight battery, im assuming that they are sucking more juice then they should??...If i move the servos really fast..i can practically bring the prop to a stop!!...i have 3 other planes and ive never seen this problem b4....anyone know whats up?
Old 07-21-2003, 01:51 AM
e-bird
Maybe put a ampmeter in line to C just how much the servo is drawing the compare to a bare servo maybe a bad servo even. CU
Old 07-21-2003, 02:21 AM
quyetflyer
Thanks...acutally i did some investigating and realized that the speed control that they came with my package was rated for 7cells/three micro servos...8 cells/2 micro servos.....im running 8 cells with "4" micro servos...sounds like it could be the problem..anyone concur?
Old 07-21-2003, 03:39 AM
e-bird
Could be but servos don't draw that I just tryed it a 300 standard
servo draws about 200 mills bare.2 amp unless they bottom out. CU
Old 07-21-2003, 12:08 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
It sounds like your battery is not capable of producing the Amps necessary to run everything. The added load from the servos causes the battery voltage to drop, and the low-voltage circuitry to kick in.
If the ESC is rated for X servos, you can't use X+1 servos. The BEC will get hot and burn out.
Old 07-21-2003, 02:58 PM
quyetflyer
figured it out...the person who put my package togheter had no clue what they were doing and my speed control was way underated....i fixed the problem...went brushless!!
