what prop size
MA
what prop size
I have an exceed monster power 46 with a turnigy 60 amp plush esc and the largest battery I can fit in the plane is a 3300 mah 5s1p. I am using an 11x6 prop and just barely getting 3 min. Does anyone have any ideas on how to get more time out of this set up. I was going to try a 12x5 prop but I'm not sure what to do. I really can't get a bigger battery because it won't fit so any info would be appreciated.
TN
RE: what prop size
3300mAh and 3 minutes suggests an average of 66A... assuming you are not at WOT continuously your peak amp draw must be well over that...maybe too much for the ESC. Even if you reduce prop size drastically and cut your amp draw in half, you'll still only get 6 minutes.
RE: what prop size
OK, take this with a LARGE grain of salt, because I'm new to this hobby, but ...
I've been researching .40-.46 equivalent motors for a Telemaster project that I'm easing into. I've been looking real close at this particular motor and with a rating of 680Kv isn't it a high torque/ low rpm kind of beast? Threads I've run acrossfrom happy usersare talking about 12x6 and 14x6 props. Seems with a small, low pitch propthe 46has more than enough muscle, but not enough speed so it's inefficient. You're burning up the amps, but not moving the air you could be moving with it. Not too stealany thunder fromMr Powers, but you need monster truck tires for monster truck torque. JMTCW
TN
RE: what prop size
That motor is rated for 40A continuous/800W max.... on 5s that's about 43A....if you are only getting 3 minutes then maybe your pack is not up to snuff... or you are drawing way too many amps even with only an 11x6 on 5s. Putting a far larger prop on will only increase the amp draw!
RE: what prop size
Yep, my apologies (shoulda put ?s at the end of most of those sentences inmy post).
Basicallyif the prop were undersized, it could be spun for a long time but not move the plane very well (low power consumption combined with poor efficiency). So, in this case, one of the numbers is a lie, and since he didn't burn out the ESC (60A rating drawing 66A), the mah rating of the battery is suspect? See, I got the right punctuation there this time <G>.
RE: what prop size
I think if you put anything bigger than an 11x6 prop on this beast, you'll blow the esc. I just burned up an esc (60A plush) using this motor with a 12x6 apc with 5s2p 3000 in paralell. With a 11x6 I'm drawing around 850 watts. I kinda wonder if this motor really is a 680kv motor or mislabeled, wattage in seems kinda high with only a 11x6 prop
