Help with speed controlers
Hello, I was wondering if someone could answer a question I have about a speed controler that I am thinking about ordering. I know that certain motors require certain capacity ESC's. I was wondering if I can use a GreatPlanes C-50 HighPower High Freq. ESC with BEC with any motor since it is the top model ESC that greatplanes offers? I am going to be using it to control a speed600 Magnetic Mayhem reverse rotation motor. Is this ESC going to work ok for me in this use? Or do I need a specific model for the motor that I want to use? Thankyou for your responses in advance!
Steven |
RE: GP C-50 speed controller
Yes, that C-50 will work with any brushed motor. My only query is whether you actually need the full 50A capability with a 600 motor, and whether size/weight is of any concern. This C-50 is physically big, and weighs 34g which is fairly hefty. If you are not going to exceed 30A, then you could be better off with the C-30 which is just under 20g. Half an oz here and there does add up.
Cheers, Phil |
Thanks for the quick reply Phil! I hadn't taken the added size and weight of the C-50. If I decided to change to a brushless motor later would the C-30 be ok to control that too?
No. A brushless motor requires a completely different ESC. Brushless motors run on three-phase AC, and the circuitry to create that current is not the same as the simple on/off switching circuitry in a brushed controller.
Frankly, I would stick with the C50 if you have it... Why spend more money, especially if it's money you don't necessarily have? |
Brushless motors run on three-phase AC Chuck |
RE: Help with speed controlers
One thing you might consider is buying an ESC with a programmable low voltage cutoff (LVC). This would be important if you decide to get into li-poly's later. I don't believe the ESC's from Great Planes provide this feature.
Following up on clively's suggestion for an ESC with LVC - the only one I know of out there is the CastleCreations Pegasus 35P ($49.95) on their web page. If it is anything like their Pixies it will be superb!
Cheers, Phil |
Wow, I hadn't checked my email in a while! thanks for all the great info!
So if I understand correctly, with the CastleCreations Pegasus 35P I can either run Nicad's or Li Poly batteries? and thta will power speed 400-600 ferrite or cobalt motors? can anyone tell me if the GP C-30 will power the same variety of motors? Like any good modeler I already have my second plane picked out before I have even recieved my first and it uses a speed 400 cobalt motor. If the Pegasus 35P will work for both and the C-30 wont that thats the way I'm going to go....Actually I'm already leaning that way already but I value input from all thoes who have a great deal more experience than I do. Thanks a lot again for all the great resopnses! Steven |
The ESC really doesn't care about the type of battery; it can't tell. You can use LiPoly batteries with the C-30, but you lose the protection of the LVC. The LVC on the C-30 kicks in too late. Therefore, you have to be very careful and land as soon as the airplane starts to loose power. If you draw LiPoly batteries down too far, you can damage them.
There is no problem using a larger ESC with a smaller motor. Excess capacity is not a problem. The biggest current draw your ESC will see is with the "600" size motors. Now, if you're planning on using modified car motors, these can draw upwards of 40 Amps or more. A 30-35 Amp ESC like the C-30 or Pegasus 35 simply won't have enough capacity. |
