GWS IPS A motor on 3 Lipoly?
Can I run a GWS IPS A motor on 3 LiPoly batterys being careful not to run much at full throttle? This is on a 4.6 ounce plane. Don't know if the motor will take this or not but need a bit more power at times.
Thanks, Bill |
RE: GWS IPS A motor on 3 Lipoly?
Yes, you could, BUT unless you are very careful with your prop size and throttle you WILL fry the motor. If your amp draw is limited to 1.5-2A you may get away with it, but don't sue GWS if you blow it. Why do you WANT to use 3s when 2s will get all you can get out of an IPS A?
Cheers, Phil |
Heh heh. Check out Greg Covey's review of the Edogfight.com T3D CAP on Ezone. That's why :)
Hey flierbk, I'll bet you a donut that that's the plane you're asking about. |
having tried various prop/throttle settings on the little GWS motors -I really can't recommend the combo of 3 cell li-Po.
When I tried the setup on my test stand-Ialso tried small wire --as a resistor --and got hot wire as well as a hot motor. Maybe there is a controller which can do the job right --by giving an effective lower voltage -(below the typical 3 cell output.) Or maybe a small enough prop -If anybody know a good safe way of dropping the 3 cell output without simply wasting the power as heat -please let me know. |
out in the piccolo world we save our little tail motors on 3 cells by using extremely high frequency speed controllers, look for some of the 100k units out, should work fine on 3 then...
