Standard size 400 brushless
Does anyone know if there is anyone out there making a brushless motors with the same dimensions of a stock 400 motor (380). I want to use some of the old gearboxes that I have but can't find a brushless motor that will fit perfectly. The Mega motors come close but the shaft is 3mm and I need it to be 2.3mm I believe. Any help would be appreciated.
RE: Standard size 400 brushless
Eflite Park 400, Himaxx 2025 series are what I can come up with off the top of my head, but be careful. Many "Speed 400" gearboxes aren't designed to handle 200 Watts, the kind of power a brushless "400" class motor is capable of.
You can also get pinion gears bored for 3mm shafts. |
