Minor issue with my JEti ESC
Hi,
On my Jeti I have a minor issue with the throttle. I have to move my throttle stick about two to three clicks up form idle to get the motor running. Any clue to how I can get it to start right after i move the stick? Do you think it could have anything to do with my endpoint adjustment? |
RE: Minor issue with my JEti ESC
Make sure your throttle channel has 0 trim and that the stick is as far down as possible before arming the ESC.
My throttle stick is always all the way at idle when I arm the ESC and I have zero trim...Never had this issue with my other esc of another brand.
flypilot,
I am experiencing the same thing with my JETI 08 Advance Plus, only in my case, I have to push the throttle 1/2 way up before the motor starts . . . Have you found a solution to this? |
Check your ATV and/or EPA settings for the throttle on your transmitter.
