Jeti brushless controler not working. HELP
Guys
I have two Jeti brushless controlers, 18 and 30 amp, that are doing the same thing. When I first power them up they will start a sequence of 5 single beeps followed with 5 double beeps and will continue that sequence as long as the power is on but the motor will not start. I have tried the program card to see if that would cause the controler to work with no success. Any ideas? Thanks for your help, Larry |
RE: Jeti brushless controler not working. HELP
Try reversing the throttle channel. I believe that will fix your problem... To know if it will work first try and plug in the battery to the controller wile the throttle stick is at full. It sounds like it is going into the programing mode and that means that it thinks that it is at full throttle.
Devin,
Thanks for your reply. You are partially correct. I have a computer radio and the end point throttle trim was off enough that the esp went into the program mode as you said. I found the problem by using another transmitter on that frequency and the esp worked, then I knew what the problem was so adjusted the end point of the throttle control and the motor started. Was really frustrated for awhile. Thanks again Larry |
No problem;) I hate little problems like that they take up allot of time !
