RCU Forums
-   Brushed/Brushless motors, speed controls, gear drives (https://www.rcuniverse.com/forum/brushed-brushless-motors-speed-controls-gear-drives-123/)
-   -   Tower pro ESC programming (https://www.rcuniverse.com/forum/brushed-brushless-motors-speed-controls-gear-drives-123/5073052-tower-pro-esc-programming.html)
pomachantus 12-04-2006 04:53 AM
Hi all,
any one of you know sequence programming for TowerPro ESC 30amp ?
A friend of mine give me a brushless controller without any instructions.
tanks for all
critterhunter 12-05-2006 12:48 PM
RE: Tower pro ESC programming
You need to go to a thread on rcgroups.com in the Power Sources (Systems?) forum called something like "Caution" something or other, only the word is spelled wrong as "Coution". It contains mention of Tower Pro ESC or something in the title. The thread is about a month old or so. There are several versions of the ESC out there and this thread will help you determine which one and provide a clearer and proper programming manual to set it up that was done by others also having confusion over this ESC. Make SURE you figure out which version you have and set it properly or you might ruin your lipos or motor.
pomachantus 12-13-2006 10:44 AM
thank I found it
