Brushless connectors?
I'm looking into getting this combo: http://www.hobbycity.com/hobbycity/s...idProduct=4709
What type of connectors would you all suggest? |
RE: Brushless connectors?
Connector tests, in German but numbers are international
www.elektromodellflug.de -> datenbank -> hochstromsteckersysteme Automatic translation: http://translate.google.com/translat...hl=en&ie=UTF-8 -> database -> high current connector systems |
I'd just use the bullet connectors that are somewhat standard for motor/ESC connections. The smaller 0.8mm or 2mm connectors should work for an 8A system:
[link=http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8878&Product_Name=0.8mm_ Gold_Connectors_12_pairs_(24pc)]0.8mm Bullet Connectors[/link] [link=http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=66]2mm Bullet Connectors[/link] If you want to save some weight, then just solder them together. Be sure to check for correct rotation direction BEFORE you solder, though. For battery connectors, the micro Deans connectors should work fine: [link=http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=2043]Micro Deans Style Connectors[/link] |
1 Attachment(s)
MP Jet Gold connectors (1.8mm) would be ideal for an 8A system (heck, they are rated for 20A). I use 'em on the battery too.
