E-Flite Motors
Has anyone use E-Flite motors on the ASM C-130 plane or what is recommended?
RE: E-Flite Motors
Just a comment: E-flite Power 25's or 32's would be an obvious choice, but any good 500W-650W motors should do the trick. You'd need to choose the correct Kv to match up with the recommended prop size and with the battery packs you intend to use (anything from 3s-6s I suppose).
Dualsky motors are excellent: http://2dogrc.com/xmotor-3548ca5t-watts-p-2071.html |
