Cyclone battery size?
Hey guys!
I am going to purchase a Cyclone CS 480-2500 40 edf, 1400 W max. at 22.2 v. I wondered what size battery would be most efficient for this edf? The advertisements rate it at 1700 gms. with a 6 blade at 58 amps. and 1680 gms. with a 5 blade at 54 amps. I had planned to use 2 11.1 lipos, connected to a 60 amp esc. I have some conservative estimates as to the mah of the battery. But I wanted some input as to the c rating of the battery, and the motor's needs. I have heard people have used 2400, to 3400 total mah for the lipo, but have not heard if they use 20 c for each battery, or higher/ lower? Any ideas guys? Any help and opinions would be appreciated. Thanks again, David. |
RE: Cyclone battery size?
A 2400 mAh battery rated at 20C can provide a maximum current of:
2.4 x 20 = 48 Amps (not enough if you need 54 or 58 A) A 3400 mAh battery rated at 20C can provide a maximum current of: 3.4 x 20 = 68 Amps (possibly enough; see below) It is important to note that the C rating of batteries is often measured by battery makers under ideal conditions that are not representative of the conditions under which we use the batteries. To give yourself a safety margin, it may be a good idea to discount the claimed C ratings somewhat. Some RCers use 80% of the claimed C ratings. - Jeff |
