Need engine help
I have a gs racing shadow sb1 and wanna put another engine in it right now it has a r15st in it does anybody know what other engines are the same? I've searched for almost a week now and can't find any info
looks as if the SB1 uses a SG style crankshaft, so your options are pretty good, most any engine in the .12-.20 range.
traxxas pro 15
traxxas 2.5(R)
Dynamite .19 Mach 2
SH18 --- make sure either a SG style crank version, a short threaded crank version (you will need a pilot shaft), or a long threaded crank (you will need to trim the crankshaft AND get a pilot shaft).
hope that helps.
traxxas pro 15
traxxas 2.5(R)
Dynamite .19 Mach 2
hope that helps.
