Most powerful .28 engine?
#101
RE: Most powerful .28 engine?
I just scoured the net, but I cannot find any pics of the sleeve port configurations of the Mugen Ninja MR21 and MR28 engines. Anyone who has these engines, can you post up pics of the sleeve ports? I am curious whant makes these engines as good as they are.
More importantly, I am interested in the timing profiles of these engines...of course, that info will not be posted anywhere on the net.
#102
My Feedback: (9)
CT
ORIGINAL: SAVAGEJIM
I posted this link above, there are pics of the .28's internals on page 1.
http://lstforums.com/forums/viewtopic.php?t=9201
#103
ORIGINAL: claudacio
ORIGINAL: SAVAGEJIM
#104
ORIGINAL: SAVAGEJIM
I will write a reveiw of the Ninja 28 soon.... But i will say a few things that i already know.... The Ninja .28 is not an explosive over the top .28 like a Nova 528, where even 1/4 throttle would result in violent tire spin..where the throtte feels like an on off switch, which makes it very difficult to control... The Ninja .28 is a whole different animal, the carb metering and modulation is phenominal, it gives you extremely accurate control over the engine's output, making driving in low traction circumastances a non issue, as this motor has a very delicate touch for a .28 and does very well on the infeild... But when you get the big Ninja to the back straight and peg the trigger the Ninja 28 flat out screams.. This motor has insane top end run out, and pulls well past whenthe other .28's and most .21's run out of breath.. the top end of this motor is nothing short of scary.... And since the motors power is so tractable it acelerates the tuggy faster then any other motor i have yet run.. Also the Ninja 28 gets goo run time for a 28.... So in short dont expect some big bad monster truck engine as the Ninja 28 is thouroubred race engine designed for track racing purposes... It truly feels like a race .21 with a 40 shot of NOS ..as the powerband perfectly mirrors that of the Ninja .21, just with more power
#106
I purchased a NovaRossi .28 it came with a roto start. I put this motor in my Fusion Outlaw it had the top-end speed clutchbell on it. Most Fusions that are equipped with the stock .21 Thundertiger motor on a short track with the top-end speed gearing never hit 3rd. My Fusion Outlaw does even on this short track. I took the roto-start off and made it a bumpstart .28 and the rate of my acceleration improved . This is a great motor. Custom Wolfpack Radicals Heat Sink head on motor.
#108
Wow, third speed on an on-road car! With a .28 big block, that engine has the torque to force the moment of inertia of the gears and clutch shoes (and the rest of the drive train!) to cause them to open in a lick. No wonder you can hit that third gear easily!
#109
considering that will the ninja .28 then be a good engine for a mayhem truggi because i´m looking for a lot of acc and a great top speed is the ninja then the right choice?? or is there other engines you guys can say is good??
#110
ORIGINAL: SAVAGEJIM
#111
Banned
I would have to agree on the Novarossi N528XR 8-port.
We have afew with some basic mod work,but even stock,they produce some nasty power.
WWW.BadboyHobbies.com
#112
ORIGINAL: nitrohead5300
.......................It has no problem at all hitting 3rd thanks to the HP and torque of the .28 The only bad thing I can say is the NovaRossi .28 is a little thirsty drinks fuel a little bit but for the performance i get ot of it I don't mind.
ORIGINAL: SAVAGEJIM
this is tru the novarossi 528 sucks fuel like a caddi............im just wondering what the top end speed on that fusion???? with that motor and a reallly tall single speed ratio i bet it could get moveing
#113
Same here, if you have access to a laser speed trap or you are elctronically savvy enough to make one, run your Fusion at top speed trough it and let us know how fast that puppy goes!
#115
FL
there is a replacement for displacement but only when there is a big diference in rpms... a race quality .28 will rev just about as high as a race .21 so assuming that they both have a similar powerband (for speed have the max tourque at higher rpms) then the .28 WILL go faster. and you can gear it lower because of the extra power so thats even more speed. street racer your saying things like a 19,000 rpm engine vs a 8000 rpm one...that is a rediculous difference and its not near like that in rc. so WITH THE SAME ANOUNT OF REFINEMENT as a .21 a .28 WILL go faster
#116
Ok guys here's where im at i got a new OS .18 cv-r on friday and put on the 17tooth and 64 tooth and i can beat a jato 3.3 all the way up to 47 mph b/c we ran out of room. I think with the 24 tooth and 56 tooth i should hit some very high speeds concidering i did 2 test runs at 54 and 55 mph without tuning the engine and the temp was around 140 - 160. If i get a werks .28 or a something like that would i hit speeds of 80+ mph?
#117
ORIGINAL: Oliver_Klozov
#119
Is this Ninja mr28 the same engine as the Falcon rs .28 I heard from my model shop it is but I am not sure also what pipes are good on these engines the Falcon rs I mean.
#120
There were three versions of those MR Ninja 28's - the Ninja, the Falcon, and the Boss. All the same, with different names, colors, etc... for different markets I guess...
#121
OH
