Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Problem I'm experiencing ... Help
Old 08-27-2007 | 09:30 AM
LordGeek's Avatar
Default Problem I'm experiencing ... Help
I currently have a Mugen MBX5T Prospec in which I'm running the RB Concepts C6BB T7 (Turbo) Team Edition. The issue I'm having is the clutch bell bearings .. for some reason, I go through both bearings on the bell at least once every race .. now I went and purchased 10 ACE ceramic bearings thinking that this would eliminate the issue .. NOT. I have gone through all 10 bearings within 1 1/2 months. The clutch bell is the standard for the Prospec (13T) as well as the spur (46T).
Anyboby have any ideas as to why this is happening ?
Old 08-27-2007 | 09:33 AM
Default RE: Problem I'm experiencing ... Help
when you say you are going through them what do you mean? are they siezing up or what are they doing??
Old 08-27-2007 | 09:38 AM
LordGeek's Avatar
ORIGINAL: VIPER458
Meaning that the bearings are basically torn appart to shredded !!
Old 08-27-2007 | 09:49 AM
SAVAGEJIM's Avatar
That is a sign that something is out of round. Your CB could be imbalanced, your spur and the shaft it goes to might be out of roune of the shaft on the sour or your engine could be bent.
Old 08-27-2007 | 09:50 AM
oh... sorry got no clue then. never had that happen to me before...[&:]
edit: that could be it. (what jim said) never thought of that.
Old 08-27-2007 | 09:58 AM
proptop's Avatar
My Feedback: (8)
Is there excessive clearance between the bearings outer race and the bearing bores in the clutch bell?
I had a clutch that would do that...and even w/ new bearings I could wobble the clutch bell. The bearing bores were too big (just a couple thou. ) but apparently that was enough to cause problem? You have a lot more powerful engine than the one I had, as well.
I put a new clutch bell on it and that stopped the bearing problem.
Don't know if that's gonna fix your problem, but it's worth a shot to measure the bearing bores to see? Can you wobble the clutch bell even w/ new bearings?
Old 08-27-2007 | 10:35 PM
mentorman's Avatar
Or maybe not enough clearance, there should be a hair of end play, otherwise the races will fry.
