Kyosho Sandmaster
Kyosho Sandmaster
I am on a mission to rebuild and revive the old Nitro buggy Kyosho Sandmaster. Any help with this would be great.
http://kyoshosandmaster.blogspot.com/
RE: Kyosho Sandmaster
Anyone no where I can source body shells for a Kyosho Sandmaster.
I believe this would be where you could find one.
http://www.udisco.com/hobbies/inv/KYOS08.HTM
Search for body, I believe it's SM16.
Anything you need to know, just ask. I've had/ have more of these than any one person should.
They're so simple and fun, I just can't seem to keep them away.
I have only used the two made by Kyosho. With the ST and MK Sandmasters, it was the standard gear with no slipper clutch. With the Tracker and RAV4(Sandmaster variants) models, they used a gear with a few more teeth, and the center is a bit different to accomidate the slipper. To change gearing, you change the clutch bell.
