Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Pull Starts
Old 08-02-2008, 11:04 AM
kersplat
kersplat's Avatar
Default Pull Starts
I see a few people stating pull starts cause a loss in power. Unless you have a dyno, I seriously doubt it that anyone can tell the difference (in performance)between the engines with one and the engines with a standard backplate.For those who have an engine with a pullstarter they say "robs power".....Check your carb settings.[>:] I have two same vehicles ,"single speed " on each. One with a "pull start" OS 12 and one with a "Bump start" OS 12. Both cars have the EXACT same accelleration in a drag race side by side all the way at WOT. Can there be any better proof other than a .08 difference in BHP, found on a dyno? I think not. Really, in a race, it is not always the fastest car that wins. It is mostly the car with the most experienced driver.
Old 08-02-2008, 11:10 AM
twomanytoys
Default RE: Pull Starts
Well other than hp ratings its a proven fact that you lose rpm's. In most cases it can be about 5000rpm's. Thats a huge power loss right there. It may not be a noticable in low rpm's but top speed will suffer.
Old 08-02-2008, 11:20 AM
kersplat
kersplat's Avatar
SPECIFICATIONS
OSMG2102
Displacement: 0.18 cu in (3.0 cc)
Bore: 0.629 in (16.0 mm)
Stroke: 0.590 in (15.0 mm)
Practical rpm: 3,000-32,000
Output: 1.35 hp @ 28,000 rpm NOTE THE NUMBERS!!!!!
Weight: 10.4 oz (296 g)
Includes: 203 air cleaner
Requires: glow plug, manifold and muffler or tuned pipe.
11881 18CV-RX ABC Parts listing
SPECIFICATIONS
Stock Number: OSMG2101
Weight: 8.4 oz (238 g)
11870 18CV-R ABC Parts listing
These are dyno numbers. If these were false then it would be false advertising and a legal matter. DONT give in to race track rumors and BS!
Old 08-03-2008, 02:16 AM
Spetz
I think the pullstart itself wont affect power, but it'll still make a difference in acceleration
It's just extra weight the engine has to accelerate. It's like adding heavier rims to a car. It wont "lose" power but of course it'll be slower as the engine will need to work harder to get the heavier bits to speed
As far as 5000rpm less... I really doubt there would be such a huge difference
And anyway, for there to be such a big difference, that means there would be so little power in those last 5000rpm that when driving that revrange would not only be useless but it would never get there, pull start or not.
I'm not saying pullstarts don't affect performance, but it's no huge deal, and it's a convinience thing.
That being said, when I added a lightweight flywheel I noticed my car was more responsive, so I am sure a bit of weight makes some difference
Old 08-03-2008, 06:31 AM
iamnot
imho, tuning is far more important than whether an engine is bump or pull start
next (or maybe even first), in a race situation, would be driving ability.
then somewhere farther down the list would be how the engine was started
there's a condition in psychology that says
if you are expecting something to change
then you will very likely perceive that it has done what you expected
you can only reliably claim a performance increase by removing the flywheel
if someone else drove it before and after w/o ever knowing what was changed
or even if something was changed
you changed it expecting crisper response
therefor you preceive that response is crisper
Old 08-03-2008, 08:09 AM
Spetz
I also retuned it once the new flywheel went on...
But, with my real car, when I swap rims over I most definately feel a difference
Old 08-03-2008, 09:39 AM
twomanytoys
The one way shaft either inside or outside the case will decrease rpm output. Anything that has rotating mass will affect rpm's and power output. Install a larger heavier and smaller lighter flywheel on an engine and you will see what difference it makes.
Figure this one out then.
LRP Spec 3 Pull start
Power Output: 3.81 PS
Useable RPM Range: 2,000-33,0000
Engine Size: .28 cu in (4.58cc)
Bore: .73" (18.5mm)
Stroke: .63" (17mm)
Number of Ports: 6+1 (6 intake, 1 exhaust)
LRP Spec 3 Non Pull Start
Power output: 3.95 NPS
usable rpm range: 2,000-38,500
Bore: .73" (18.5mm)
Stroke: .63" (17mm)
Old 08-03-2008, 10:21 AM
Spetz
Twomanytoys,
Sure on paper/dyno there might be a difference
But what I was saying is, can you imagine how little power the engine is making past 33,000rpm for it not to be able to spin that extra bit of weight? If you take that into consideration, those extra 5000rpm are useless and will never be reached once you add car weight, tyre drag, driveline drag, wind drag etc
Like I said, at most it might make a small difference in acceleration
Old 08-04-2008, 11:05 AM
378's Avatar
My OS 18 CV-RX can't even top itself out with the truck's load on it. I'm not losing any power to the recoil.
The ONLY way the recoil is going to affect performance is by adding another four ounces to the total vehicle weight. That's it. More dirt clings to the damn car if you run offroad!
Also, the recoil actually fell off my old NT16. Fell completely off, as in one-way was clear of the output shaft. Zero power increase. I didn't know it till I shut down three tanks later and found the recoil sitting free on the center driveshaft.
And for those of you bringing dyno graphs, remember that these little engines and dynos don't get along. One guy measures one engine, the next guy measures the same engine setup on a diff dyno and gets completely differant numbers, and then the next guy is running 30% instead of 20%, and the guy after that has a differant pipe. Same engine, differant testers, all radically differant numbers. The amount a pullstart can possibly draw falls well into the deep margin for error that dynoing these engines has. Hundreths of a horsepower? I highly doubt that is accurate to begin with...This also swings both ways. There's no telling what affected either dyno graph. I'm sure they're pretty close, probably down to the tenth of an HP....but we're talking a few hundreths here.
Edit: And if the one-way bushing sucks down 5 grand, the bushing sucks ass. That's all there is to it. I've always wondered why the startshaft never got a bearing, but instead got that bushing...
Old 08-04-2008, 11:40 AM
Spetz
378,
The theory is not that the one way takes away so much power, but that the starting shaft does due to the added spinning weight.
Basically under acceleration the engine not only has to move the car but also accelerate an additional mass (the starting shaft)
Anyway though I also think the difference is too small to care about
Old 08-04-2008, 12:31 PM
iamnot
ORIGINAL: Spetz
there ya go, right there
probably the smartest thing said in this thread
Old 08-04-2008, 12:55 PM
Spetz
Yay I'm a genius!!
Old 08-04-2008, 01:36 PM
kersplat
kersplat's Avatar
Engine Size: .28 cu in (4.58cc) More conservative timing
Bore: .73" (18.5mm)
Stroke: .63" (17mm)
Engine Size: .28 cu in (4.58cc) Higher more advanced port timing
Bore: .73" (18.5mm)
Stroke: .63" (17mm)
The differences in RPM and BHP is NOT due to the pull starter.
Old 08-05-2008, 05:46 AM
hspower
spetz
Old 08-05-2008, 06:15 AM
Spetz
Yeah?
Old 08-05-2008, 06:46 AM
mordraid
ORIGINAL: twomanytoys
Bore: .73" (18.5mm)
Stroke: .63" (17mm)
Bore: .73" (18.5mm)
Stroke: .63" (17mm)
Those aren't exactly the same engine. The one with the pull start is designed with lower RPM for monster truck ( who usually got 2 speeds) and the other is designed to go in truggies. That's why you see a 5000 rpm difference.
The pull start is (i my opinion) a way for a potential air leak. It is easier to have an air leak in the back plate with a plastic cap than with the original back plate.
Old 08-05-2008, 07:59 AM
chookman46
If you have a starter box and you can use it to start your car you are far better of with a bump start engine. Whether it is noticable or not you will have to agree it takes extra power to spin the shaft and the drag on the one way bearing. That is a fact whether you can tell the difference or not is debatable.
The main reasons I dont like pull starts is that they can be unreliable, OWB slipping, broken cord, broken springs. And the biggest problem is that its another place for a leak to occur. Have seen engines get dusted from sucking fine dust back in the pull start before.
Old 08-05-2008, 09:04 AM
Spetz
The problem with bump start is lugging it around, especially if your car stalls a bit down the road where in reality all you need to carry is a glow plug
And also the initial cost. I don't know how much they cost but I assume the setup + battery would be at least 60-80 USD as opposed to just pull start which is $10 more or so
Though, I agree that it is a potential air leak. In fact mine leaked air and oil so I bought new backplate + starting shaft
Old 08-05-2008, 09:14 AM
hrdcoreglf
It is not really about the loss of power, it is about the added potential for air leaks which can cause potential tuning problems. The pullstart itself is mostly plastic, so it is not very heavy, but the OWB and start shaft and backplate do add weight to the rear of the engine. If you can win with either engine it doesn't really matter. It is more driver than machine.
