What do you use to seal you carb, etc?
GA
RE: What do you use to seal you carb, etc?
For the carb, at the carb/engine block junction and around the pinch bolt
For the engine, between the block and the backplate
apply any sealant very sparingly to mating surfaces, it does not take a lot to do the job
Permatex copper is not Nitromethane proof and therefore should not be used.... instead use RacersEdge sealant or Threebond 1211.............that copper stuff will work for a bit, but as soon as Nitro makes contact it will start to melt.....
ORIGINAL: supertib
Isn't the reacers edge stuff silicon too?
I've always used the red RTV and its never seem to melt.
What do yall use to seal the needles since I heard green slime will make the O-rings fall apart?
Don't get me wrong, I have used Permatex many many times...... but at the time it was the best thing I could find.... Since then I started using Threebond 1211 or Racers Edge which are both a superior products.... Permatex will work, but it is not Nitro proof and will slowly dissolve under constant exposure..of course it will hold its seal for a while but nothing like the other 2 products I use.........
The Racers Edge and Threebond seem to me to be identical products other then color.. they are a type if silicone, but are based off different solvents, they smell completely different then any other silicone I have seen... When the tubes are new they are almost a creamy texture that is easy to spread and use, almost like a thick hand soap...I use this stuff to fill my cranks after I have lightened them, once it cures it feels like very firm silicone............
My Feedback: (8)
supertib...that silicone you describe sounds a lot like "flowable" silicone that is typically sold in auto parts stores to seal water leaks around windshields.
I have been using it for a couple of years...and seems to hold up well. It doesn't have that strong vinegar (eye watering/nostril burning ) odor...or at least not quite as bad anyway.
at autozone they have 700deg copper gasket in a gold tube i am shure it wont melt i have used it with no probs .I have a pico red dot .26 on the way is the racers edge the way to go .
ORIGINAL: proptop
1211 has a Latex smell to it, zero vinegar smell....
