RCU Forums
-   Car Nitro & Gas Engines (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/)
-   -   engine proplem please help (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/10002129-engine-proplem-please-help.html)
albobaz 09-14-2010 04:28 PM
<div style="text-align: center;"><span style="font-family: Verdana;"><span style="font-size: medium;">hi i have a big proplem in my baja 5b engine it habend to me <span class="short_text" id="result_box"><span title="">Twice and i changed my engine
so my piston is stuk in the head and i cant move it and i used the engine only one tank
my carb idol is rich and the engine is full of oil is that the </span></span><span class="short_text" id="result_box"><span title="">Reason
</span></span><span class="short_text" id="result_box"><span title="">Although my engine is rich but the engine </span></span>Temperature is to hot
and if i lifted the car i can see the wheels moving
so can u heeeeelp me please
and thank u all
</span></span></div>
controlliner 09-14-2010 09:48 PM
RE: engine proplem please help
Take it to Dubai hobbies, it is a few minutes from City Center mall. they have technical support staff there.
albobaz 09-15-2010 05:45 AM
i now this shop they dont now any thing and they will take 30 $ only for opining the engine
and i now the best shop in the uae but i want to fix it by myself
pe reivers 09-15-2010 04:59 PM
Heat the engine cylinder. This will loosen your piston. (when hot, the liner expands more than the piston)
If your mixture is too rich, the oil is thinned. because of the piston pinch in a new engine, this will stick the piston in top dead center. This is normal.
Use more oil for running in, and do not flood the engine. Heating the engine before starting also helps.
A tight piston is the sign of a good engine. You should respect it. The engine will give better power, and last longer.
albobaz 09-15-2010 07:25 PM
<div align="center">thank u man..... so i should lean it a bit
and how can i heat the cylinder without damaging it
and the problem was from the oil after all
and thank u so much
</div>
Argess 09-15-2010 10:47 PM
Are you sure there's pinch?....He's talking about a Baja 5B engine...that's a gasoline engine with a piston ring...shouldn't be any pinch.
Piston should never get stuck unless it is so flooded the combustion chamber is full of fuel and the piston won't move any further. In that case, take the sparkplug out and crank it over a few times.
If it's really stuck.....remove the exhaust and look at side of piston through exhaust port. Do you see any damage?...Like heavy scoring? If so, it has to come apart for repairs.
If the piston really is stuck due to heat, then be careful about heating the cylinder head.....there's gasoline around, so don't use an open flame. Try a hair drier. I can only imagine a piston being stuck this way if the engine was running way too lean and got very hot and after shut-down, teh ring/piston somehow stuck to teh cylinder wall.....but the whole thing sounds unlikely to me.
bigdogkanicsar 09-16-2010 12:08 AM
ORIGINAL: Argess
i agree.
and once you get any fuel out that may be in there, spray some WD-40( penetrating ) in the spark plug hole to help free up any stuck piston rings.
if it comes free it's gonna smoke a little after startup and should disapear or at least to the normal smoke amout being it's a two stroke.
Argess 09-16-2010 07:21 AM
Yes. And if there is scorring when you look through the exhaust, perhaps the wrong type oil was mixed with the gasoline? That could also be a reason if you're sure it wasn't running lean.
albobaz 09-16-2010 07:52 AM
thanks man i did what u told me i heated the cylinder it works
you saved my wallet from paying 300$ lol
man u rooooock
albobaz 09-16-2010 07:55 AM
thank u i heated the cylinder with a <span id="result_box" class="short_text"><span style="" title="">Hair Dryer hhhhhhhhhh and it works
no dameges lol
thank u verey much
</span></span>
albobaz 09-16-2010 07:58 AM
ORIGINAL: bigdogkanicsar
ORIGINAL: Argess
i agree.
okk but the wd - 40 will not help it will stop burning
and thanks
albobaz 09-16-2010 08:00 AM
ORIGINAL: Argess
no i dont think that it was lean it was very riiiiiich
is it a problem if it was too rich
Argess 09-16-2010 08:06 AM
Well Big Dog.....we can't win them all......LOL.
bigdogkanicsar 09-16-2010 10:49 AM
yeah it happens.
i'm the king of bringin back things from the dead.
the wd-40 actually helps free up stuck rings and really nothing else.
it's just for freeing purposes upon start up and anything after that is up to the oil in the fuel.
