Too much engine compression .21 picco
Any suggestions?? Barely turn it over with my fingers as its very very tight..Impossible to start on starter box.. Tried heating it and got temperature up to 200 deg but was still hard to turn.. Tried loosening glow plug as well.. Maybe add some lub inside sleeve?? Out of options...
RE: Too much engine compression .21 picco
I've never come across an engine that will not turn over on a good starter box with a loose plug and being warmed up. What starter box have you got? Are the batteries good?
Is this a new engine? Is your starter box fully charged?
just picked up a jato recently and traxxas recommended i lube the sleeve on the first few starts. pinch was way too tight.
Actually using a dewalt 18v drill battery in my starter box.. If that wont start it i dont know what will.. Engine i believe had a fresh pinch.
All you have to do is pre-heat the engine, it'll turn over.
