broken piston - how bad?
1 Attachment(s)
I there, this was the first time it hapenned to me.
I was runnig my buggy and suddently my engine suddently stoped. When i tryed to start it, i noticed the flywheel was locked and when i opened it my piston was broken just a little at his bottom (as seen in pic). I cleaned the engine and it´s running fine. Should i worry and change the piston or it will be fine for some time? thanx ;) |
RE: broken piston - how bad?
you need another piston andprobably also a sleeve I wouldnt advise to run that engine with out changing them
| All times are GMT -8. The time now is 05:03 PM. |
