Opening nitro engine
Hey,
I have never opened one of these little buggers before and I want to open mine to check that it still looks ok and also to give it a proper cleaning. Im most interested in removing the piston and the sleeve. How would I do this and do I need to do anything particular when opening the engine? Also whats the best way of getting rid of inner engine gunge ( my piston is black! )...thanks for any input! Jocke88 |
RE: Opening nitro engine
I don't know why you'd disassemble it unless it was necessary. Is it running ok? Is it worth enough in total so that replacing parts would make sense? Does it have a pull-start?
Its a Kyosho .21 Gx something....its not working properly, it keeps on flaming out. I think it may be lack of compression. I just want to open her up and give her a good cleaning...ne tips on how to do this?
Ps she has a pullstart Thanks |
Whip the head off (4 bolts in the top of the engine). And see if you can prise the sleeve out from the top. Just make sure you know which way round it comes out! If you can get it out like this you will be lucky, if not...
1. Remove the pullstart, very carefully as you dont want it to fly to bits!!, then remove the rear cover of the engine. 2. Take the head off (if you havent already). 3. You now need to get the cylinder liner out. If you cand get it out from the head of the engine, push it out from underneath with a bit of wooden dowel. 4. Slip the con rod from the crank pin, then the piston and con rod will fall out. 5. If you want to remove the crankshaft you have to remove the flywheel. After you have done this you can push the crankshaft out. Check to fo while its in bits: 1. Check the fit of the piston in the liner. It should get stuck close to TDC if you try to push it through. If it will go past the top of the liner its time for a new piston/liner. 2. Check the crankshaft for signs of wear or burn marks where it goes through the bearings. 3. Check the bearings in the case. These should be totally smooth and not feel jerky or gritty. Put it back together in the reverse order. Use plenty of normal oil when you do, as this will protect the engine when you frst fire it up. Word of warning: Make sure you are spotlessly clean when you take the engines apart, you dont want any grit in there. Make sure you pay close attention to the orientation of the piston and liner in the crank case. (You can mark them with a permanent marker if you like)! These engines are very simple with very few moving parts. As long as you pay attention to the direction everything comes out you will be fine. Also when you put it all back together, run it slow for a tank or so to allow it to all bed back in again. I have my engines apart more often than a lot of people do. Never have any problems :) Hope that helps, David :) |
Be prepared to get some new screws for your head. I always strip mine when I take mine off.
Hi jocke you got a PM in Swedish.....
The number one thing to do before taking you engine apart is to clean it very very well! Have a clean surface to work on and then start the disassembly. To see if it still has compression all you need to do turn the flywheel. If you ever did that when it was new you will know the difference. There should be a tight spot that is hard to turn with your fingers.
| All times are GMT -8. The time now is 03:59 PM. |
