os engines
i was just wondering if someone could tell me i have a v one sII with an os max .12 tr(p)-t but i want more power and want to put in the os max .21vz-r, but is the pilot shaft on both engines the same size so i can use the same clutch??
My next door neighbour has a cen ct4-s and whips me so i think this should even things up a bit what do u think?? |
RE: os engines
You already asked this, and as I said before, O.S. .18 TZ will drop in with no mods at all, and will smoke that CTS4 if you have good enough gearing.
RE: os engines
Yea, and if you can manage to get the power to the pavement instead of spinning up your tires.
| All times are GMT -8. The time now is 09:23 PM. |
