RCU Forums
-   Car Nitro & Gas Engines (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/)
-   -   second start (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/4498563-second-start.html)
madlax18 07-13-2006 06:14 PM
second start
Im currently running an ofna glow engine. I can get it started, however it doesnt start for a second time when its warm or hot. how can i fix the problem to be able to start my car consistantly ?
gasrc 07-13-2006 10:13 PM
RE: second start
Unfortunately, there is no way to answer your question without being right there with you. Take it to a track on a practice day, and someone there will almost certainly help you.
You can have a bad plug, vacuum leak, bad glow plug gasket, bad fuel, or it could simply need proper tuning.
Philster 07-14-2006 09:35 AM
RE: second start
This one is easy.
Advance the throttle using the transmitter trim control. Some big blocks are funky like this. When warm/hot, sometimes you need to advance it as much as 20-40% or more to get it to fire. It won't run away on you. But to be safe, the first time, try placing the vehicle so it can't run away. You'll get used to it. It will fire, the revs will build slowly and then you just trim it back to its normal idle setting. You'll be surprised how far you will need to advance the throttle trim.
