need help
hi i am replacing my 24.7 xtm motor in my mammoth with the new axial 28rr ive never done this before and i cant figure out how to take the clutch shoes and flywheel off please help thanks
RE: need help
im not sure what kind of clutch is on the mammoth but if it has one continous spring wrapped around the shoes then the shoes and everything should just slide off. unless there is an e-clip holding it on. if there is then take it off and try sliding it off. if it has individual springs on each shoe then you can pry a small screw driver between the clutch nut and slide the shoe off. and the flyweel is just held on w a nut.
RE: need help
thanks ill try that
| All times are GMT -8. The time now is 08:39 PM. |
