RCU Forums
-   Car Nitro & Gas Engines (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/)
-   -   Engine Trouble (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/6222846-engine-trouble.html)
brian4558 08-10-2007 09:28 PM
Engine Trouble
Breaking in a Tower Hobbies .25 Tower Terror. Engine fired but is running crazy fast. Clutch engaging and tires are moving. Checked the needles and set at 4 1/2 high, 3 1/2 low and the idle stop from the factory was at 1/4 inch. the manual said "1 mm from the body" and I screwed it in TIGHT but only got it about 1/8th inch away. What gives? Is it broken and how can I fix it?
Codeblack 08-11-2007 01:48 AM
RE: Engine Trouble
ORIGINAL: brian4558
umm, usually when you want lower idling, you have to unscrew the idling screw
---RC PiNYoT--- 08-11-2007 09:32 PM
RE: Engine Trouble
ORIGINAL: brian4558
If you're sure needle positions are correct and idle gap is fine, I'd start checking for airleaks.
unableelephant 08-11-2007 10:01 PM
RE: Engine Trouble
i had that prblm and after trying so many things... i decided it was an air leak i had no idea where so i replaced all my fuel lines,checked all my O rings and sealed off every possible place on the engine with engine sealant/gasket maker...it worked pretty good atleast i can deal with the way it runs now...my needle settings need some tweaking but its definetly manageable now
SAVAGEJIM 08-12-2007 08:05 AM
RE: Engine Trouble
ORIGINAL: Codeblack
ORIGINAL: brian4558
I agree, you want to screw the idle screw out LOOSE to lower your idle speed, not in tight.
