RCU Forums
-   Car Nitro & Gas Engines (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/)
-   -   engine temp (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/6260582-engine-temp.html)
maxximillion 08-19-2007 09:57 PM
engine temp
what would the highest temp i should allow for my lrp 28 spec 3
Codeblack 08-19-2007 10:30 PM
RE: engine temp
after the break-in no more than 270F
jatoracing33 08-19-2007 10:49 PM
RE: engine temp
just like every engine...some say no more than 240, no more than 260 and so on...i say somewhere between 240-280 is the safe range
ttoks 08-20-2007 05:19 AM
RE: engine temp
generally i would say don't worry about temps as every engine is different, and there are to many variables, temp is not a very accurate tuning tool, performance and smoke trail are much better indicators, but i would say no more then 300 F under normal running conditions if you must have a temp.
supermod 08-20-2007 08:37 AM
RE: engine temp
aslong as ;)you keep it under 300 its ok
dude54325 08-20-2007 04:58 PM
RE: engine temp
during break in it should be from 200-220.
