VENOM Electronics?????
Anyone own any Venom? I wanna get the module with Temp, volt meter, and F.S. I'll be running a twin...does this mean I need two? Venom-Racing.Com doesn't explain the SPEED METER how it installs. Anyone use them?? Pics???
RE: VENOM Electronics?????
I've got the Venom Smart Temp if thats what you are referring to. Yes you will need two as they have one heat measuring loop, but they connect to the throttle servo and to your receiver, so you prob don't have enough free connectors.
I'm very happy with mine, very easy to set up, but I'd recommend getting a temp gun too and using it to put the Venom's loop on the right ring of your engine. It says in the manual that you should put it around the lowest ring, but this can measure temperatures higher than the glow plug is actually at. They are very accurate, you just need to make sure its fitted properly to do so. Here is a picture of mine installed, like a normal failsafe you put the throttle into the Venom, and the venom into the reciever. The heat loop goes around the engine head, you can see mine going around the back and through my strut to the engine: http://i12.photobucket.com/albums/a2...5/634b63dd.jpg I don't have the speed meter though |
Maybe I'll have to get a different Rx. Heres what I had in mind. I already have a fail safe, then 2 of the single funtion temp monitors , one single funtion volt meter and one speedo. Do I need it all? No, but it would be cool. Others have told me the Smart isn't accurate....but its got to be calibrated to a hand held......makes sense. Thanx
Windowlicker
Which fin did you find the loop to be most accurate on? I have one of those venom temp meter, but must be an older one as it runs on a 1.5 volt button cell battery In the manual it said to put it on the second fin not first |
| All times are GMT -8. The time now is 11:10 PM. |
