RCU Forums
-   Car Nitro & Gas Engines (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/)
-   -   New engine problem (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/7703282-new-engine-problem.html)
digital_cop 07-07-2008 12:56 PM
New engine problem
Hello All,
I put a new 25 engine in a second hand XTM mammoth today. Problem is it seems very tight when pulling the pull start. It did fire a couple of times but never started. I assume there will be some tightness on a new motor but this seems a little excessive, any ideas???
Colt4g63 07-07-2008 01:19 PM
RE: New engine problem
Take a heat gun or a blow dryer to the head and heat it up to about 200 degrees. This will cause the internals to expand and it will be much easier to turn over/start. You will want to do this for quite a few tanks as its easier to get started and easier on the piston and rod during break-in as well.
supermod 07-07-2008 03:17 PM
thats called alot of pinch;)
*FULL-REVS* 07-07-2008 10:42 PM
pinch is good :D
