RCU Forums
-   Car Nitro & Gas Engines (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/)
-   -   glow plug problems (https://www.rcuniverse.com/forum/car-nitro-gas-engines-269/8622068-glow-plug-problems.html)
Arrish 03-27-2009 12:43 PM
glow plug problems
Hi im having engine problems’ well basically my glow plugs keep blowing? I have no idea why my jba engine has bin fine up till now.
I have just replaced the con rod and its turning over fine so I took it out for a run just now’ I put a band new glow plug in’ it ran great for about 3 minutes at a good running temp and then just stopped’ the plug had gone? I swapped it out and shore enough the same thing happened? I don’t understand what would cores this to happen and could it be related to the new con rod.
wga22 03-27-2009 06:10 PM
RE: glow plug problems
how long are you getting them to run? A few tanks, or immediatly?
Has the compression changed on your engine? Are they cold or hot?
dacaur 03-27-2009 06:13 PM
I would take it apart again and look for debris... if a little spec of metal or something hits the plug, it will burn out....
gearjammen 03-27-2009 11:23 PM
take your low speed jet and back it out half a turn your to lean on the bottom then adjust your high speed for temp
dacaur 03-28-2009 12:30 AM
Being too lean on the bottom end wont make glow plugs burn out, and wont affect the top end at all. It will mess with your idle.
Arrish 03-28-2009 06:52 AM
thanks guys. I gona take it apart again' its got worse now and runs like its to rich bogging down and stalling all the time but I have leand it out loads[&o].
gearjammen 03-28-2009 09:35 PM
to lean on the bottom will cause it to burn glow heads
