rustler
can i put a exceed .18 motor on my rustler which has a .15 motor? will it make it faster?
RE: rustler
the 2.5 in the rustler is plenty powerful for the truck. I don't think you'll see much of a performance increase with the 18
RE: rustler
If you exceed 2.5 you will have to modify entire drivetrain.... but, it can be done ... I have a 3.3 in my rustler and it is very fast...
starting out the 3.3 would eat gears and all of rest of drive train.... but it is fun and fast now... |
RE: rustler
i don't think the exceed .18 would tear up anything. exceed isn't known for top quality, unless they used a sh .18, like they did with the .28 in the mad beast. in that case it should be quite the upgrade, though i believe if your gear mesh is set right, you shouldn't tear anything up. my friend mounted an ofna .28 in his rustler, and it is still running good.
RE: rustler
ORIGINAL: rcmodnutt If you exceed 2.5 you will have to modify entire drivetrain.... but, it can be done ... I have a 3.3 in my rustler and it is very fast... starting out the 3.3 would eat gears and all of rest of drive train.... but it is fun and fast now... |
| All times are GMT -8. The time now is 01:35 AM. |
