Quick qustion
Hi all new member here name's Cort, Ihave a quick qustion i have a revo with os.21tm in and it runs awsome starts right up brand new engine plenty of smoke shifts on time only problem is is once i hit let it idle for 4 seconds or hit the breaks to hard after a high speed run it dies any ideas on what could be causing this? Icheck the carb with the engine off and the breaks didn't close the carb so
RE: Quick qustion
During the idle, what's it doing?
1/ If it is gradually slowing down and dies, the LSN may be too rich. 2/ If it gradually speeds up and dies, the LSN may be too lean. Since it dies when letting off the throttle as well, I'd guess #2.....the LSN may be too lean. These arn't the only reasons, but it's a start. Your HSN may be too lean and that's all there is to it, but I'd start with observing the idle as above. |
RE: Quick qustion
ORIGINAL: monsterkawi209 Hi all new member here name's Cort, I have a quick qustion i have a revo with os.21tm in and it runs awsome starts right up brand new engine plenty of smoke shifts on time only problem is is once i hit let it idle for 4 seconds or hit the breaks to hard after a high speed run it dies any ideas on what could be causing this? I check the carb with the engine off and the breaks didn't close the carb so |
RE: Quick qustion
ya id check the idle first, try giving the idle screw either half a turn, or maybe a whole turn
RE: Quick qustion
Thanks for all the responces guys I think i've got it setttled for now she's running pretty good
| All times are GMT -8. The time now is 04:43 AM. |
