Carden Aircraft Post threads here related to the Carden Aircraft line
35% extra rudder servo setup
Old 12-21-2013, 04:15 PM
flatlandmike
My Feedback: (17)
flatlandmike's Avatar
Default 35% extra rudder servo setup
Are any on you running you rudder servo in the tail or are all using pull pull?
Old 12-21-2013, 08:52 PM
sensei
sensei's Avatar
I always run them in the tail, push, pull, best way to go.
Bob
Old 12-21-2013, 08:58 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
I'm assuming that you are wanting to run a single servo? I did this once by mounting the servo on the bottom of the fuse just forward of the tail wheel mount. I then ran a couple CF pushrods to a double horn bolted to the bottom of the rudder. I have only seen a single servo single pushrod done once.
Old 12-22-2013, 03:04 AM
flatlandmike
My Feedback: (17)
Im a big fan of push pull. I'm just concerned if the plane is going to CG easily if i put the servo in the tail of a 35% carden extra. My Pro has the servos in the tail but I dont know where the 35% was originally intended to have the rudder servo.
Old 12-22-2013, 08:28 AM
speedracerntrixie
My Feedback: (29)
The Carden was designed to have the servo set up on Pull pull. I'm curious to why you think it would need the weight towards the tail? That airplane should balance just fine with a DA 100 ( not the light version ) or 3W 106 as those were the most popular engines at the time that airplane was designed. Look up the weights of those two engines and compare to the engine you are going to use. You should figure out what to do from there. You would also be able to adjust CG via battery placement and component selection.
Old 12-22-2013, 06:07 PM
flatlandmike
My Feedback: (17)
Its not a question of needing weight in the tail. I want the rudder on push pull, it is a much better setup than pull pull. But if the needs of CG dictate a pull pull so be it.
More research to do.
Old 12-23-2013, 03:18 AM
sensei
sensei's Avatar
Here is a single servo setup I ran in the tail of my 35 %er a few year ago.
Bob
ID:	1950449   Click image for larger version
