Carden Aircraft Post threads here related to the Carden Aircraft line
32% Carden Yak 54 Construction
Old 09-10-2006, 12:08 PM
My Feedback: (76)
swk550's Avatar
Default 32% Carden Yak 54 Construction
I thought I would start a Carden 32% Yak 54 construction thread. I'll start with some fuse frame construction photos.
Enjoy,
Steve Kessler
ID:	521938   Click image for larger version
ID:	521939   Click image for larger version
ID:	521940   Click image for larger version
ID:	521941   Click image for larger version
ID:	521942   Click image for larger version
ID:	521943   Click image for larger version
ID:	521944   Click image for larger version
Old 09-10-2006, 12:12 PM
My Feedback: (76)
swk550's Avatar
Default RE: 32% Carden Yak 54 Construction
Here are some pictures of the engine installation.
Enjoy,
Steve Kessler
ID:	521946   Click image for larger version
ID:	521947   Click image for larger version
ID:	521948   Click image for larger version
ID:	521949   Click image for larger version
ID:	521950   Click image for larger version
ID:	521951   Click image for larger version
Old 09-10-2006, 12:18 PM
My Feedback: (76)
swk550's Avatar
Here are some photos of the wing construction.
Enjoy,
Steve
ID:	521954   Click image for larger version
ID:	521955   Click image for larger version
ID:	521956   Click image for larger version
ID:	521957   Click image for larger version
ID:	521958   Click image for larger version
ID:	521959   Click image for larger version
ID:	521960   Click image for larger version
ID:	521962   Click image for larger version
Old 09-10-2006, 12:23 PM
My Feedback: (76)
swk550's Avatar
Here are some pictures of the stab construction.
Enjoy,
Steve Kessler
ID:	521965   Click image for larger version
ID:	521966   Click image for larger version
ID:	521967   Click image for larger version
ID:	521968   Click image for larger version
ID:	521969   Click image for larger version
Old 09-10-2006, 12:28 PM
My Feedback: (76)
swk550's Avatar
Here are some pictures of the turtle deck sheeting and rudder installation.
Enjoy,
Steve Kessler
ID:	521971   Click image for larger version
ID:	521972   Click image for larger version
ID:	521973   Click image for larger version
ID:	521974   Click image for larger version
ID:	521975   Click image for larger version
ID:	521976   Click image for larger version
ID:	521977   Click image for larger version
Old 09-10-2006, 08:28 PM
My Feedback: (45)
zzw26n's Avatar
Thanks Steve .................
Old 09-10-2006, 09:11 PM
My Feedback: (76)
swk550's Avatar
I used 1/4" depron foam for the canister floor plate. I ended up splicing in balsa for the area at the rear end of the MTW TD75K canisters. This way if the canister rubs, it will only touch the balsa. Also here are some pictures of the throttle servo mount. I still need to cut the air exit hole in the 1/4" balsa sheeting behind the landing gear mount plywood.
Steve
ID:	522280   Click image for larger version
ID:	522281   Click image for larger version
ID:	522282   Click image for larger version
ID:	522283   Click image for larger version
ID:	522284   Click image for larger version
Old 09-11-2006, 08:23 AM
Just curious, are the anti rotation tabs on your stabs part of the kit or are they your modification? Nice build!
Old 09-11-2006, 08:43 AM
Hey Steve,
This is Wayne (Former Jetero member)
Your build looks good.
We did the stabs the same way on my new Carden 260 and its working out really well.
Old 09-11-2006, 11:11 AM
Steve:
Now that I see the effort you have put into the lightening, I think you will beat your target weight.
Nice work!
Mike
Old 09-11-2006, 03:35 PM
My Feedback: (24)
I too am doing this stab modification. In fact I have changed all of my giant scale builds to this style of attachment. In the pic below you will see from left to right stabs from a 40% Carden 330, 35% Hurley Extra, and a Great Planes Extra 330L. I dont want to watch another plane go in because of stabs departing the aircraft, trust me it is not fun to watch. [:@]
Ric
ID:	522587   Click image for larger version
Old 09-11-2006, 07:00 PM
Looking good steve. I noticed you are using a bolt to hold your wings. What's going to prevent your bolt from braking loose inside the wing ? From the picture it looks like the bolt is going through the balsa and it looks as if it was held in place by a drop of CA.
Albert
Old 09-11-2006, 08:15 PM
My Feedback: (76)
swk550's Avatar
The 1/4-20 aluminum wing bolts are attached to the wing root with 1.5" diameter light ply washers. These washers prevent the bolt from being pulled out of the balsa root rib. The bolt is CA'd to the washer. The washer is then glued to the root rib. I match sand the wings to fit the side of the fuse. Then I take a dremmel and remove the wing root styrofoam to allow a snug fit up of the bolt head and washer. The root rib is then glued to the wing with Elmers Ultimate Polyurethane glue. On the inside of the fuse, I fill in the space with 3/8" balsa. Then I align the wings and finally install the 1/8" hard plywood bearing plates and the anti-rotation dowell washer socket. The wing is held in place with 1/4-20 nylon wing bolts. Hope this clarifies.
Steve
ID:	522662   Click image for larger version
ID:	522663   Click image for larger version
ID:	522664   Click image for larger version
ID:	522665   Click image for larger version
ID:	522666   Click image for larger version
ID:	522667   Click image for larger version
ID:	522668   Click image for larger version
Old 09-13-2006, 02:55 PM
My Feedback: (7)
Thanks Steve ,
Great build . I'm thinking of do the yak after my 330 .
Darrell
Old 09-13-2006, 03:29 PM
I guess my question is what will prevent the bolt from spinning besides the drop of CA ? Iwould be afraid to make the nut too tight and breaking the bolt loose from inside the wing and having it spin freely.
Albert Santiago
Old 09-13-2006, 07:01 PM
My Feedback: (76)
swk550's Avatar
Albert,
The thin CA wicks into the screw threads. I've used this method for over 10 years. I've never had to tighten the wing nut to the point where the screw broke loose. I believe you would make a major wing root indent on the side of the fuse first.
Steve
Old 09-18-2006, 07:02 PM
My Feedback: (76)
swk550's Avatar
More Fuselage Construction Photos
Enjoy,
Steve
ID:	526479   Click image for larger version
ID:	526480   Click image for larger version
ID:	526481   Click image for larger version
ID:	526482   Click image for larger version
ID:	526483   Click image for larger version
ID:	526484   Click image for larger version
ID:	526485   Click image for larger version
Old 09-18-2006, 07:08 PM
My Feedback: (76)
swk550's Avatar
Canopy Frame Construction Photos
Enjoy,
Steve
ID:	526498   Click image for larger version
ID:	526499   Click image for larger version
ID:	526500   Click image for larger version
ID:	526501   Click image for larger version
ID:	526502   Click image for larger version
ID:	526503   Click image for larger version
ID:	526504   Click image for larger version
ID:	526506   Click image for larger version
ID:	526507   Click image for larger version
Old 09-20-2006, 08:00 AM
BBW Walt's Avatar
Nice build Steve: Question? Are the sides for the center section hatch formed from one piece or are they sheet blocks glued and shaped?? I'm refering to the area where the canopy sides will glue on..Thanks Walt
Old 09-20-2006, 05:00 PM
My Feedback: (76)
swk550's Avatar
Walt,
The sides for the canopy prame are 1/8" balsa.
Steve
Old 09-24-2006, 06:52 PM
My Feedback: (76)
swk550's Avatar
Cowl and landing gear, exhaust turtle deck installation
I followed Carden's recommendation for installing the cowl in two halves. I messed up the front bottom styrofoam sheeting. So I decided to form the landing gear and exhaust turtle decl from light balsa. Attached are some photos.
Regards,
Steve
ID:	529725   Click image for larger version
ID:	529726   Click image for larger version
ID:	529727   Click image for larger version
ID:	529728   Click image for larger version
ID:	529729   Click image for larger version
ID:	529730   Click image for larger version
ID:	529731   Click image for larger version
ID:	529733   Click image for larger version
Old 10-06-2006, 09:50 AM
My Feedback: (76)
swk550's Avatar
Canopy construction
After framing up the canopy, I glassed the surfaces with 3/4 oz glass cloth and Pacer finishing resin. I am using a Bill Hempel pilot head. The instrument panels are from Carden Aircraft. The interior surface is painted with Rust-oleum "American Accents" Stone Creations grey. I bought the spray can at Home Depot. The hardest part is fitting up the clear canopy. After a trial measurement, I cut the clear plastic. Then I used a dremel 1/2" sanding drum and cut a 1/16" deep slot to fit the canopy flush with the frame. I used 6 oz glass cloth and reinforced the inside of the frame as this area gets a little thin after cutting the 1/16" fit-up slots. I used RC56 glue to attach the clear canopy to the frame. You need to let the RC56 glue to set up for at least 24 hours. I had a few areas that needed to be reattached. The last photo shows where I am blending the clear plastic to the frame with 30 minute epoxy and microbaloons. The next step will be to sand the surfaces and start the primer finish,
Enjoy,
Steve
ID:	536085   Click image for larger version
ID:	536086   Click image for larger version
ID:	536087   Click image for larger version
ID:	536088   Click image for larger version
ID:	536089   Click image for larger version
ID:	536090   Click image for larger version
ID:	536091   Click image for larger version
Old 10-19-2006, 11:28 AM
My Feedback: (45)
zzw26n's Avatar
Steve,
Any reports ?
zz
Old 10-19-2006, 09:22 PM
My Feedback: (76)
swk550's Avatar
Painted Cowl and Canopy
Sorry I have not made much progress lately. Seems like work gets in the way of building.
I have finished painting the Cowl and Canopy. I am using PPG K-36 primer. The true red and light metallic blue is Dupont Imron paint. The white and insignia blue is PPG concept paint. I had some weave and seams showing on the canopy after my first light primer. The cowl has a few pin holes. I simply used DAP vinyl spackle, thinned with water to fill in the imperfections. Then I sanded off the K-36 with 220 grit followed with 400 grit sand paper. After filling in the imperfections, I put a normal medium coat of K-36 primer on again. This time I only had to do a mild 400 grit sand. All color paints are thinned with reducer (approx 20% for Imron and approx 50% for the PPG paint). I use a Harbor Freight HVLP touch-up spray gun. I paint on a mild first coat of color and let it dry for five minutes. Then I follow up with the final color coat. From the pictures, you can see I get a good gloss color.
Hope this helps,
Steve
ID:	544189   Click image for larger version
ID:	544190   Click image for larger version
ID:	544191   Click image for larger version
ID:	544192   Click image for larger version
ID:	544193   Click image for larger version
Old 10-20-2006, 06:36 PM
You have the most informative construction thread I have ever seen. Nice work on the plane and thread. Thanks!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
