Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic > Carden Aircraft
 c'mon. Easy Question.what glue for vertical fin 35% Edge >
Carden Aircraft Post threads here related to the Carden Aircraft line
Old 08-19-2007, 05:00 PM
3littlefonzies's Avatar
Default c'mon. Easy Question.what glue for vertical fin 35% Edge
This is my first big build. I bought the plane flamed up in the bones.
I am about to instal the vertical fin on my 35% Edge. I'm wondering what glue to use to attach the fin.
I Am thinking that Exterior wood glue will do the trick. Seems to bond very well to foam and balsa alike and dosn't seem brittle.
But i just want to make sure that it will hold. Or do I need to use some 30 min epoxy or Gorilla Glue or something.
Chris
Old 08-19-2007, 10:33 PM
My Feedback: (31)
Default RE: c'mon. Easy Question.what glue for vertical fin 35% Edge
i have used exopy seem like 90% of the time 15 or 30 min type
Old 08-20-2007, 03:43 AM
poxy. You can do lots of reposition untill its perfect and still get a strong bond.
FWB
Old 08-20-2007, 10:13 AM
30 min epoxy. Don't play games.
Old 08-20-2007, 04:27 PM
Definately 30 minute epoxy. I also mounted a small plywood piece in the bottom of mine and attached it using a nylon bolt to a plate in the fuselage. Maybe overkill, but that sucker ain't never coming off.
Kraig Krumm
Canton, OH
Old 08-20-2007, 06:59 PM
30 minute epoxy.
Albert
Old 08-29-2007, 07:40 PM
i would definatly use epoxy, just put together a qq yak and used wood glue on the horizontal stabiliser and it jus squeezed out luckily it became loose during running in and i hadnt got it in the air so used exposy and strong as hell now.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
