Genesis – 3rd gear engagement settings
TN
CEN or Andrew can either of you guys please us out with the third gear engagement settings. Everyone that I have seen in multiple online forums appears to be having the same problem with third gear.
I have personally spent many hours trying to dial in third gear and have been unsuccessful thus far. At this point I would feel more confident if I started all over again from the factory default settings.
Can you please post how many turns from all the way tight the factory settings are for the two adjustment screws? Or even better give us the settings from how many turns out from all the way tight from your trucks that are properly engaging third gear.
Any and all advice would be greatly appreciated.
TN
UTVols,
We recommend setting the 2nd speed to 5 1/2 turns out (both screws equally) and the third speed at 6 1/2-7 turns out (both screws equally). Hope this helps out.
In the meantime I dont have an actual date when we will post the announcment but please bare with us as we are working very hard to address the issues with the first batch of trucks.
_____________________________
Best Regards
Best Regards
