Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 How to get the spur gears off the main shaft? >
CEN Racing This forum is to discuss all CEN Racing products.
Old 01-28-2005, 08:57 PM
Default How to get the spur gears off the main shaft?
How do I get the spur gears off? Do I take off the bevel gear? Do I remove the clutch?
Old 01-29-2005, 01:09 PM
Default RE: How to get the spur gears off the main shaft?
the spur gears are held on by set screws and a snap ring.... just be careful when separating the gears so you don't break anything...
Old 01-29-2005, 06:03 PM
Suppose I were to find or get a metal spur gear manufactured. What would be the next weak link? Anyone tried it?
Old 01-29-2005, 07:00 PM
poor judgement's Avatar
indeed they have! i have one of the copper gears here (47T), that were advertised on here a bit back - the guy i got it from has been running his for ages with only the usual diffcup n driveshaft probs. i speak to him on msn, but he is icelandic, his english aint too good!
i havent tried the copper gear yet - yes its heavy - as i run a 42/38 setup in the rally, but i will be trying it on the mt setup, if it ever arrives....
his cen mt is well modified, extended chassis, tmaxx shell, twin steering servos, tmaxx wheels etc etc
i can ask him any questions u may have, the next time he is on, if u like.
doh, forgot - the genesis 43 tooth steel spur allegedly fits the alloy 2nd gear hub for the funfactor/gx1 etc, so it should fit the alloy first gear hub too. the copper 47t i have is a copy of the red gear tho, not sure if i can get it to work with the alloy 2nd gear hub...
Old 01-30-2005, 12:12 PM
I have to say, that snap ring was a pain in the *$& to get off. I finally got those gears replaced. Now I just have to get my throttle servo replaced. It twitches a lot. Hopefully CEN will warranty replace it.
Old 01-30-2005, 01:57 PM
its a right nightmare getting that clip off mate! circlips pliers are the way to go, or prepare urself for a few cuts, pokes and skin trappings!!
Old 02-26-2006, 04:44 PM
Amen... I had to replace my 47t Spur gear for the first time and it actually cut the metal on the one-way bearing. Too much Guiness when they designed that one... BRILLIANT!
ORIGINAL: poor judgement
Old 02-26-2006, 06:40 PM
I've got all the parts i think I'll need to install the genesis spurs on my FF on the way form toyhaus. Worth a try anyway. Last time i changed a spur i couldn't find my snap ring pliers so there i was working on it with 2 90 degree pics for like 15 mins lol.
PJ, Got any pics of that guys FF per chance? Dual steering servos... hmmm. How would you do that?
Might be worth a try as ai have about 3 or 4 stock maxx and cen servos layin around.
Old 02-26-2006, 06:53 PM
I'm khantemplating just leaving it out.
Old 02-26-2006, 08:13 PM
no pics - sorry, he extended the chassis in the fuel tank area by about 2 inches, moved the tank towards the back and put a 2nd servo where the tank usually sits, opposite the regular steering servo. he changed it back iirc, to just the one servo.
Old 02-26-2006, 08:50 PM
How did he control the steering? Did he just splice the wires together so they were both controlled from one wheel?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
