CEN Racing This forum is to discuss all CEN Racing products.
genesis clutch bell help
Old 10-19-2005, 08:58 PM
butt_tricks
Default genesis clutch bell help
ok due to me being stupid and the fact that i lost a screw for the engine mounts i burned up the pinion gears. My question is that has anybody taken them off and how did they do this. Thanks
Old 10-20-2005, 12:04 PM
RunX
Default RE: genesis clutch bell help
To take the pinions off on the clutchbell use the oven(heat) Pre-heat the oven at 220 C and leave the clutchbell in there for 15minutes or so.The heat will soften the treadlock and use waterpump pliers or a wide mouth plier to hold the clutcbell while it is still warm,dont let it cool down for to long. before working on it.Turn the first pinion anti clockwise with another pair of pliers and work your way through it.Ask someone to help you if you can not do it alone.
Remember tread lock and the shims for the correct spacing of the pinions.
Old 10-20-2005, 12:46 PM
butt_tricks
Thank you RunX will try once i get back home after work today.
